Codes
General questions about VTool
donsito
Codes
Post by donsito »
Hi everyone, I used vtool today and I got the following codes. Does anyone know what they mean or what the fix is please? I have googled them but not found definitive answers to some of them.
It is also worth saying I have no experience at all in car fixing but with dealer prices nowadays, I need to learn some basics.
Thanks to the dev for making this tool by the way.
And thanks in advance for any responses.
Re: Codes
Please provide a VIN. You can message me in PM if you don't want to publish it here
donsito
Re: Codes
Post by donsito »
pm'd you. thank you
Re: Codes
Here is what I found in Vida
BCM-B111167 Electric park brake enable. Algorithm Based Failures. Signal incorrect after event
The Brake Control Module (BCM) monitors the requested action of the caliper motors, parking brake.
• The vehicle is in usage mode active or higher.
• The brake caliper motors, parking brake, do not reach the target state for a requested action within an allowed time.
None.
ASDM-C104115 Vision System Camera Heater. General Electrical Failures. Circuit short to battery or open
The Active Safety Domain Master (ASDM) monitors the road in front of the vehicle. The control module has a built in radar and camera. The ASDM camera heater is used to heat the windshield in front of the camera and the radar to reduce the risk of condensation blocking the view.
• The vehicle is in usage mode active or driving.
• The circuit is open or short-circuited to battery voltage.
The ASDM camera heater is disabled.
CEM-U201F00 External receiver.
The Central Electronic Module (CEM) receives external data from the Multiband Antenna Module (MAM).
• The vehicle is in usage mode active.
• The Multiband Antenna Module (MAM) is not responding or is sending an invalid response.
None.
VCM-U105000 is a known issue. You need to visit a dealer and load SW to reset the battery lifetime counter in VCM. For this routine VCM PIN11 is required which is unique. So can't be done easily via tools like VTool. Details: https://static.nhtsa.gov/odi/tsbs/2024/ ... 8-0001.pdf
ECM one is missed in Vida as well
donsito
Re: Codes
Post by donsito »
Top man. I appreciate the thorough reply.
Thanks again
