CCM-B14E114 - climate control module low side driver
Posted: 05 Mar 2025, 16:59
by deniska9106
Всем привет. CCM-B14E114 - climate control module low side driver - general electrical failures - circuit short to ground or open. С чем может быть связано, может кто сталкивался. Спасибо
Re: CCM-B14E114
Posted: 11 Mar 2025, 02:39
Information
The PTC heaters are controlled by a relay in the fuse box, rear. The relay is controlled by the Climate Control Module (CCM). The control module monitors the relay coil circuit.
Test run criteria
• The vehicle is in usage mode convenience or higher.
Detection criteria
• The load current is too high.
None.
Re: CCM-B14E114 - climate control module low side driver
Posted: 11 Mar 2025, 09:02
by deniska9106
Благодарю
