Webasto xc90 2020
Posted: 23 Nov 2025, 14:09
Всем доброго дня! Не получается снять блокировку вебасто. Подскажите может что то делаю не так?
Лог программы
18:28:58 [Info]: Finished reading fault codes for all modules
18:29:03 [Info]: Opening climate service window
18:29:07 [Info]: Starting routine "CPM unlock 2"
18:29:13 [Info]: Starting routine "CPM unlock 2"
18:29:48 [Info]: Reading fault codes...
18:29:50 [Info]: Switched usage mode to Active, idling...
18:29:55 [Info]: Reading fault codes for all modules with mask 20...
18:29:57 [Info]: Reading fault code details
18:29:58 [Info]: Finished reading fault codes for all modules
18:30:03 [Info]: Preparing, please wait...
18:30:06 [Info]: Switched usage mode to Active, idling...
18:30:11 [Info]: Erasing fault codes for all electronic modules...
18:30:14 [Info]: Erased fault codes for: ASDM, AUD, BCM, CCM, CEM, DDM, DEM, DIM, ECM, HCML, HCMR, IHU, PDM, POT, PSCM, PSMD, PSMP, RML, RMR, SAS, SCL, SODL, SODR, SRS, TCM, TRM, VCM, VDDM, WAM
18:30:14 [Info]: Reading fault codes for all modules with mask 20...
18:30:16 [Info]: Reading fault code details
18:30:16 [Info]: Finished reading fault codes for all modules
18:30:19 [Info]: Disconnecting...
18:30:20 [Info]: Disconnected
Может надо подождать подождать по дольше Starting routine "CPM unlock 2"
Постоянно выдает ошибку ccm-b15b693.
Заранее спасибо
Лог программы
Заранее спасибо
