Здравствуйте!
перестал почему-то работать сегодня vtool
выдаются вот такие ошибки.
Вчера еще все работало.
можно как-то побороть?
11:22:08 [Info]: VTool 1.0.2.285
11:22:16 [Info]: Connecting...
11:22:17 [Info]: Trying to establish a connection...
11:22:17 [Info]: Found vehicle announcement: (VIN: LY---------------, address: ('169.254.4.10', 55169), logic: 0x1021)
11:22:19 [Info]: CEM responded in 0.05 sec
11:22:19 [Info]: VIN: LY------------------
11:22:21 [Info]: Successfully connected in 2.37 sec
11:22:21 [Info]: Detected Mild Hybrid car, CMA platform, brake control BCM2
11:22:21 [Info]: Reading CEM details...
11:22:21 [Info]: CEM is supported by VTool
11:22:21 [Info]: Initialization finished
11:22:25 [Info]: Updating car information
11:22:25 [Info]: Updating car configuration
11:22:28 [Info]: Programming available: configuration, keys, history, oem
11:23:02 [Info]: Opening Edit window
11:23:14 [Info]: Programming....
11:23:21 [Info]: Switched usage mode to Active, idling...
11:23:26 [Info]: Performing pre-programming actions for MHEV car
11:23:26 [Info]: Checking preconditions...
11:23:28 [Info]: Preconditions check failed for TCAM (code: PositiveResponse, data: 01 02 06 10 02)
11:23:31 [Info]: Entering Prog mode...
11:23:36 [Info]: Reconnecting...
11:23:37 [Info]: Found vehicle announcement: (VIN: LY----------------, address: ('169.254.4.10', 55169), logic: 0x1021)
11:23:57 [Error]: Failed to unlock VGM
11:23:57 [Info]: Successfully reconnected in 5.73 sec
11:23:58 [Warning]: Unexpected result on prog request: [WinError 10054] An existing connection was forcibly closed by the remote host
11:23:58 [Info]: Idling...
11:24:03 [Info]: Checking prog session...
11:24:34 [Info]: Need to wait for: CSD, IHU, CEM
11:24:34 [Info]: Idling 5 seconds before retry...
Re: Unexpected result on prog request: [WinError 10054] An existing connection was forcibly closed by the remote host
судя по логу, модуль TCAM препятствует программированию. попробуйте скинуть клемму с основного аккумулятора на пару минут. возможно просто глюк
авто из Китая, мигала красным кнопка SOS. пару месяцев назад я параметр 77 (Assistance services) установил в 01 (without...)
вчера вернул его обратно, но вместо 02 (with assisitance ...) поставил 81 (with assistance service. ERA Glonass). все применилось, кнопка SOS снова заморгала красным.
сегодня утром попробовал поставить 77 параметр в 02, как было с завода и посыпались эти ошибки.
причем кнопка SOS теперь просто светится белым, но не работает.
основной аккумулятор - это 12В?
и еще VGM в vtool серым цветом - это значит его нет?
все это затеял потому-что изначально, сразу после покупки у меня подключался volvocars, а теперь нет...
из изменений после покупки - это изменение параметров через vtool и установка starline v96.
пытался понять почемук перестало подключаться приложение на телефоне - оно просто не находиит авто, а в самом авто - не находит ключи...
если подскажите куда посмотреть, буду благодарен.
вот полный лог:
11:22:17 [Info]: Found vehicle announcement: (VIN: LY----, address: ('169.254.4.10', 55169), logic: 0x1021)
11:23:37 [Info]: Found vehicle announcement: (VIN: LY-----, address: ('169.254.4.10', 55169), logic: 0x1021)
11:24:49 [Info]: CSD is not responding
11:24:59 [Info]: IHU is not responding
11:25:09 [Info]: CEM is not responding
11:25:09 [Info]: Idling 5 seconds before retry...
11:25:24 [Info]: CSD is not responding
11:25:35 [Info]: IHU is not responding
11:25:45 [Info]: CEM is not responding
11:25:45 [Info]: Idling 5 seconds before retry...
11:26:00 [Info]: CSD is not responding
11:26:10 [Info]: IHU is not responding
11:26:20 [Info]: CEM is not responding
11:26:20 [Info]: Idling 5 seconds before retry...
11:26:35 [Info]: CSD is not responding
11:26:45 [Info]: IHU is not responding
11:26:56 [Info]: CEM is not responding
11:26:56 [Info]: Idling 5 seconds before retry...
11:27:11 [Info]: CSD is not responding
11:27:21 [Info]: IHU is not responding
11:27:31 [Info]: CEM is not responding
11:27:31 [Info]: Idling 5 seconds before retry...
11:27:46 [Info]: CSD is not responding
11:27:56 [Info]: IHU is not responding
11:28:07 [Info]: CEM is not responding
11:28:07 [Info]: Idling 5 seconds before retry...
11:28:22 [Info]: CSD is not responding
11:28:32 [Info]: IHU is not responding
11:28:42 [Info]: CEM is not responding
11:28:42 [Info]: Idling 5 seconds before retry...
11:28:48 [Error]: Please don't try to close VTool until the flashing is finished
11:28:57 [Info]: CSD is not responding
11:29:07 [Info]: IHU is not responding
11:29:17 [Info]: CEM is not responding
11:29:17 [Info]: Idling 5 seconds before retry...
11:29:33 [Info]: CSD is not responding
12:37:17 [Error]: Unable to prepare prog mode
12:37:17 [Error]: all ECUs reset error: [WinError 10054] An existing connection was forcibly closed by the remote host
12:37:17 [Error]: Failed to download the configuration
12:37:17 [Info]: Waiting for reconnection...
12:37:22 [Info]: Reconnecting...
12:37:23 [Info]: Found vehicle announcement: (VIN: LY-----, address: ('169.254.4.10', 42363), logic: 0x1021)
12:37:23 [Info]: CEM responded in 0.02 sec
12:37:25 [Info]: Successfully reconnected in 5.68 sec
12:37:25 [Info]: Post-programming actions
12:37:25 [Info]: No need to check brake module status
12:37:28 [Info]: Sending reset to IHU
12:37:28 [Info]: Successfully sent reset to IHU
12:37:30 [Info]: Waiting for IHU
12:37:48 [Info]: IHU is awake
12:37:48 [Info]: Sending reset to PSCM
12:37:48 [Info]: Successfully sent reset to PSCM
12:37:48 [Info]: Idling...
12:37:51 [Info]: Erasing fault codes...
12:37:59 [Error]: Unable to download configuration changes
12:38:07 [Info]: Programming available: configuration, keys, history, oem
вот полный лог:
