Version 1.0.2.40
Announcements and new versions
Version 1.0.2.40
  • Major technical changes related to communication with the vehicle, especially broadcast requests. This process is now handled more correctly.
  • Full-fledged module reading has been added for modules that are not read directly and therefore could previously appear in gray in the list (BMS, OHC, GSM, IMS, BBS, WPC).
  • A content selection window has been added to the diagnostic report printing feature. Now, for example, you can print only the list of modules and software or just the list of errors.
  • In the mileage report window, which retrieves data from vehicle modules, new mileage sources have been added. Additionally, a red marker is now displayed if the vehicle reports about unwinded mileage.
  • Added mileage unit setting (km/miles). There is also an "auto" mode, where the mileage is displayed in the same units as in the vehicle.
  • Database update – new error codes have been added.
  • The headlight configuration window has been redesigned based on feedback.
  • SOC/SOH display for high-voltage batteries has been added for fully electric vehicles.
  • A brake pedal adaptation reset feature has been added.
https://vtool.info
