Version 1.0.2.136
Announcements and new versions
Version 1.0.2.136
Added:
  • DPF regeneration routine (for commercial users only)
  • Reset of the VCM backup battery counter, which clears VCM-U105000 fault code (for commercial users only). VCM11 pin is required.
  • Oil volume display (beta version)
  • Database upgrade. Added new configuration parameters, added and corrected engine types, added markets
  • Open/close commands for grill shutters
  • Knob to skip checks for buggy AAOS versions
  • Sorting by columns in Mileage dialog to sort by main / ext source types
Fixes/Improvements:
  • Reimplemented add/remove key window for better results
  • Improved HCM programming dialog and fixed a bug affecting programming of new (virgin) modules
  • Improved BCM/BCM2 reconfiguration routine to reduce post-programming issues
  • Fixed bug in SUM calibration that prevented calibration after programming
  • Fixed empty lines in mileage report
  • Many minor fixes
download
