Version 1.0.2.136
Posted: 16 Jun 2025, 02:07
Added:
- DPF regeneration routine (for commercial users only)
- Reset of the VCM backup battery counter, which clears VCM-U105000 fault code (for commercial users only). VCM11 pin is required.
- Oil volume display (beta version)
- Database upgrade. Added new configuration parameters, added and corrected engine types, added markets
- Open/close commands for grill shutters
- Knob to skip checks for buggy AAOS versions
- Sorting by columns in Mileage dialog to sort by main / ext source types
- Reimplemented add/remove key window for better results
- Improved HCM programming dialog and fixed a bug affecting programming of new (virgin) modules
- Improved BCM/BCM2 reconfiguration routine to reduce post-programming issues
- Fixed bug in SUM calibration that prevented calibration after programming
- Fixed empty lines in mileage report
- Many minor fixes
