Version 1.0.1.288
Announcements and new versions
Version 1.0.1.288
  • This version significantly improves compatibility with iCup cars with Android on board, thanks for testing s1v2.
  • The stability of the connection has also been significantly improved and now there should be no disconnects from the car.
  • The panel with control unit "tiles" has been redesigned. Now it automatically scales and does not eat up extra space
  • Fixed display of engine type on cars whose VIN starts with the letter L
  • Added a search by parameter number in the configuration filter. Now to go to parameter 200 you do not need to scroll the list, just enter 200 in the filter and press enter, the desired parameter will be highlighted in the list
  • And as a bonus, the ability to unlock the pre-heater, which is blocked after several unsuccessful starts, has been added to the Climate window section. Winter is coming soon and the topic should be relevant :) The functionality has been added in test mode, I am waiting for real feedback on unlocking from users.
